PDF from BI solution
Hi
We have a BI solution that is generating som PDF repports every night regarding production, sales.
Would it be possible to get Xibo to read PDF from a shared on our file server, or could I have our BI solution dump the PDF in Xibo library ?
Assuming that you are using 1.8 series CMS and players, then yes there is PDF module which you could use (files would need to be uploaded to the CMS).
You could also try embedding it in an iframe with fully qualified path to the file (assuming players and CMS and reach it of course).
