PDF & Flash content is not showing on Android Display for 1.8.2. Kindly suggest if any additional plugins are required to be installed on the android display.
Flash is no longer supported on Android natively. Android dropped support for it some time ago, as for pdf I am not sure, someone else may need to answer that one.
Flash isn’t expected to work.
PDF should though, assuming you’re using the 1.8.2 CMS and R102 Player. Add your PDF to the region using the PDF widget.
Please check the versions you’re using. A 1.7 series Player for example won’t be able to show a PDF from a 1.8 series CMS.
