Overlay Issue Not Displaying
Im having a issue overlaying a Date/Time Overlay i have set in my layouts. When I’m in scheduling and select overlay no layout/my overlay show. Please see picture.
James
Until this is fixed, you’ll need to create at least one campaign in the system.
Alex,
Thank you for your reply. I also found till this is fixed under EVENT TYPE if you leave it on Campaign/Layout fill in any other info you require, then go down to Campaign/Layout section and select your overlay layout because it appears, then go back to EVENT TYPE and select OVERLAY then save. That seems to also work.
James
