i have a layout with 2 regions one is under the other one, the one on top has a png with transparent box frame, the one on the bottom has a video and image items.
now everything is working fine on my android player, however when i need to update the content i cant reach the options of the region on bottom as the one on top is covering it. there should be some way to control this, maybe a list of regions that you can select whatever region someone wants to edit !! or is there some way ??
thanks for your replay, my situation is exactly like the image you posted however the smaller region is in the back and the bigger one in front, so i cant access the smaller one !!
