On premise module on other cms fork
We run a custom fork of Xibo CMS 4.4.3, forked from the official tag and ported from MySQL to Microsoft SQL Server 2022 (all SQL queries rewritten to T-SQL, running the standard Docker Compose stack — PHP/Apache + pdo_sqlsrv + SQL Server 2022 container — on Linux). The rest of the CMS behaves like stock 4.4.3 as far as we can tell (XMDS, display registration, scheduling all working and tested end-to-end with a real Android player).
We’re about to deploy Stick (Signage) players on a fully isolated LAN with no internet access, and we’re planning to purchase the On-Premise Licensing module ($210) + 15 Xibo for Android licences.
Before committing to the full purchase, we’d like to check a few things given our non-standard setup:
  1. Does the module perform any of its own direct SQL queries against the CMS database, or does it operate purely through the existing Xibo Storage abstraction layer / file exchange (request.txt / android.txt in library/android)? We want to confirm there’s no MySQL-specific SQL syntax baked into the module that wouldn’t run against SQL Server.
  2. Where exactly should the config snippet ($licence_pool_email) go — web/settings.php or custom/settings-custom.php? Our web/settings.php already includes custom/settings-custom.php automatically if present, so we’d rather use that hook than edit a file that’s otherwise generated by our deployment process. We’ve seen conflicting guidance on this in older forum threads (e.g. one referencing Xibo 2.0.3 on XAMPP/Windows).
  3. Can you confirm the licence exchange is genuinely a one-time process per device, and that it’s tied to the Android player’s hardware ID, not to any identifier of the CMS server itself? We plan to validate the whole setup on a build VM first, then clone/export that VM (Hyper-V) to the client’s production server — so we need to be sure the licence activation survives that move without issue.
  4. Is it possible to purchase the module with a single test licence first, validate the full flow on one device, and add the remaining 14 licences afterwards — or does the on-premise module/pool need to be set up with the final licence count from the start?
Happy to open a support ticket if that’s a better channel for this — just wanted to check here first in case someone has run On-Premise Licensing against a modified/non-MySQL CMS before.
Thanks!
