On Android 5.1 Font too large on player
Hello, I encounter a malfunction on Android with the size of the fonts in TEXT areas. I publish the same layout on two Xibo players: 1 Android 5.1 and 1 Windows 10.
On the Android player I have a difference between what I preview on the CMS and what is broadcast on the player (bigger on the player).
The fonts used are well diffused from the my mediatheque and the resolution in the Android profile corresponds well to that of the CMS. On the Windows player everything is OK.
I have 2 photos that shows the problem on Android: The preview and streaming on the Android player.
The palyer is a Navori Player
Thanks for your help
cordially
Gerard
Perhaps you have increased font’s size on the android device?
I believe android has a setting for that, could you check that please?
Does that happen with all fonts? (custom and the default ones)
Hello Peter,
The font setting on our android consists of a choice between 4 Options:
Small, normal, big, very big.
By default, the setting is Normal.
I modified the option by changing the fonts on Small and actually the display on the player reduces the fonts in the areas, but not enough (we are still not in Wysiwyg between Layout and display player) .
I will ask the manufacturer of the Navori player how to reduce the fonts even more.
I also did the test with regular fonts (Cloud) and the problem is the same.
Thank you
cordially
