Loaded a new campaign scheduled the campaign and off we went. All of my sites updated and started playing the new campaign. Throughout the campaign though some replay themselves which is annoying and another issue is that old layouts still play every now and then?
Them old ones need to be gone as we don’t store that particular product. I have reset cache on each display. My version is 1.8.2.
If you select the Schedule option in your CMS, click on the Select Displays field above the calendar and choose the Display/Display Group that is not displaying properly. This will then display all currently scheduled Events for that Display/Display Group. You can hover your mouse over the icons on the calendar to reveal what the event is.
Can you confirm that only the new Campaign is scheduled? If you find that old Campaigns/Layouts are still scheduled, you can click the event and select Delete.
