hi
i have Downloaded and extract the archive from Xibo-server-1.7.9 , copied the contents after unzipping it into a folder called xibo and then the xibo folder i have copied it in xammp folder but when i am try to access via http://localhost/Xibo.
i am getting an error
Object not found!
The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again.
If you think this is a server error, please contact the webmaster.
Error 404
localhost
Apache/2.4.25 (Win32) OpenSSL/1.0.2j PHP/5.6.30
