Notification if default layout is playing
Hey everyone,
Is there a way to send an email notification if the default layout is playing?
CMS version: 1.8.9
Display: Android
Cheers!
Not “out of the box”, technically it should be possible to write a task that would check for it and trigger an email notification, however it’s not something we’ve implemented.
The default layout should only be displayed if there is no scheduled content, player is downloading scheduling content or player has a problem with the scheduled content.
Alternatively the Interleave default might be enabled, which would add the default layout to the schedule.
If there are problems with downloading content, it is likely that it will trigger a notification about player downloading files too many times.
