Notification emails
I’m running xibo 1.8.2 server and notification email is not working. Is that something I have to configure in the server? Some place that I have to add smtp, pop addresses ?
Is it docker or manual installation on a web server?
In CMS the maintenance configuration is explained here https://xibo.org.uk/manual/en/cms_maintenance.html
You will also want the XTR to be working, in docker it should work without additional configuration, in manual/custom installation please see - https://xibo.org.uk/manual/en/install_xtr.html
Then the smtp etc are configured in config.env (docker) as for manual installation it will depend on your environment - on windows that will be in php.ini on linux server the php uses local MTA (so it needs to be installed) or you can have something else installed as an alternative full mail server, then you’d need to configure that.
