HI,
I’m running XIbo CMS on CentOS 7 (x64). When I run php xmr.php
, nothing happens… the terminal just returns me to a new prompt.
ZeroMQ is installed:
[root@server /home/xibo-cms/]# rpm -qa | grep zeromq zeromq-3.2.2-13.2.x86_64 zeromq-devel-3.2.2-13.2.x86_64
Here’s my config.json:
{ "listenOn": "tcp://10.0.1.10:5555", "pubOn": ["tcp://x.x.x.x:5556","tcp://10.0.1.10:5556"], "debug": false }
ps -ax | grep xmr
doesn’t reveal any running processes
netstat -a | grep 5556
doesn’t show any open ports
What could be possibly going wrong?
Thanks.
I just went through this process.
Your instructions above did not say you added the php bindings for zeromq. I found the guide here: http://zeromq.org/bindings:php
I used the pear / pecl route with success.
With the json config file you have, I had an error when starting xmr. I was trying different things but I found an example of another config file that allowed xmr to start.
I’m still learning this new version so I can’t say if this config file is right or wrong. But it did allow xmr to start.
“listenOn”: “tcp://lo:50001”,
“pubOn”: [“tcp://192.168.151.198:9505”, “tcp://lo:50002”],
“debug”: false
Then you will need to create a custom systemd script to make a service out of the evocation command so the service starts on each system reboot.
Is there any reply on this? I cant seem to make the service up either.
Thanks!
Reema
