hey, very new to xibo, a contracter came in xibo cloud hosting having issues with displaying xibo player regions on our displays, here is the log from when i booted up our display just then, can anyone assist me? any help would be great.
2020-02-05 21:47:22UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
Nombre del parámetro: Unable to set and start a media node
2020-02-05 21:47:25UI ThreadRegion - Eval OptionsUnable to start new clock object: No se pudo encontrar el tipo de Windows Runtime ‘Windows.Web.UI.Interop.WebViewControlProcess’.
2020-02-05 21:47:25UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
2020-02-05 21:47:32UI ThreadRegion - Eval OptionsUnable to start new clock object: No se pudo encontrar el tipo de Windows Runtime ‘Windows.Web.UI.Interop.WebViewControlProcess’.
2020-02-05 21:47:32UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
2020-02-05 21:47:35UI ThreadRegion - Eval OptionsUnable to start new clock object: No se pudo encontrar el tipo de Windows Runtime ‘Windows.Web.UI.Interop.WebViewControlProcess’.
2020-02-05 21:47:35UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
2020-02-05 21:47:42UI ThreadRegion - Eval OptionsUnable to start new clock object: No se pudo encontrar el tipo de Windows Runtime ‘Windows.Web.UI.Interop.WebViewControlProcess’.
2020-02-05 21:47:42UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
2020-02-05 21:47:46UI ThreadRegion - Eval OptionsUnable to start new clock object: No se pudo encontrar el tipo de Windows Runtime ‘Windows.Web.UI.Interop.WebViewControlProcess’.
2020-02-05 21:47:46UI ThreadMainForm - ChangeToNextLayoutLayout Change to C:\Users\JORGE\Documents\Xibo_Library\15.xlf failed. Exception raised was: El argumento especificado está fuera del intervalo de valores válidos.
