Does anyone know how install zeromq or xmr to synology NAS with linux as operating system because i need it for xibo. i have xibo without docker…
in advance thanks for the help and time.
also is there any possible to have a live stream on xibo such as security cam?
i have a cisco small business model wvc2300 internet wireless video camera with 2 way audio so i am wondering if its able to set up in the layout settings!?
I don’t know how you’d do that on Synology. Likely you’d have to compile it and the appropriate PHP extentions on another machine (cross compiled for Synolgy’s CPU type). That won’t be trivial to do.
If the camera outputs an HLS stream, then all Players can show that. If it outputs an RTSP stream, then Android and webOS Players can show that.
If its HLS, use the HLS widget. If it’s RTSP, use the LocalVideo widget.
thanks for your repley, i found i need HSL but i am running on windows 7 and i cant do that on higher version because my company only uses windows 7. is there anyway i can play the stream on windows 7? the HSL is a local host of the ip camera right?
HLS is HTTP live streaming. The camera would need to support it, and you’re right you’d also need Windows 8.1 or later to display it. It’s not possible to show it on earlier versions of Windows.
