We have had the problem that since the update to Xibo Digital Signage Version 3.0.2, an entered text in the text widget or in the playback widget can no longer be saved.
Although text is entered in the text field, the error message always appears: “Please enter the desired text”. No matter with which user and which authorization level.
Whether with the visual editor or without. No text is simply adopted.
Hi, could you collect a report fault troubleshoot log for that issue to see if the logs can give us an idea as to why that is happening for you. Is this for all Users including Super Admin users?
