No Displays showing up
Hi
Probably a stupid question - new to CMS - when I login to the dashboard I don’t see any displays listed or any sort of button to add one. I want to show my content on the second monitor of this system.
Display 1 - 19" monitor attached to a Mac Pro
Display 2 - 2nd apple monitor.
Thanks for your help.
~Jeff.
Hello, I guess you would have to install the Xibo client and connect to your CMS…however I don’t think there is a Xibo client made for Mac.
If you have Linux or Windows installed on your mac, you could install it and connect to your cms using your address and key.
