Next Window or Agent feature
I was wondering if there is a way to interrupt the the currently running media to show that a window or agent is available such as “Window 2 is now available” then after 5 seconds or so it resumes the current media?
We are currently using DisplayIt Digital Signage to do this but would like to move to something better. Thanks for the help.
It’s coming!
It’s called Event Driven Signage and it will be in 1.8.
You would need to write an integration application to take the message “Window 2 is now available” and communicate that to the CMS via the API. The CMS can then relay that message to the Players in realtime (using XMR which is also new to us) and interrupt the currently running layout with new content.
