Have anyone worked with LED panels and resolutions?
I need help setting it up, i have edited display settings and made a new resolution for the layout which are 384x192.
Im still getting blackbars on the actual LED, can anyone help me sort this out? I am used to work with “real” pixels as most of us
Are there more settings i need to make in the CMS or what am I missing here?
Basically you will want to have layout in not necessary the same resolution but the same aspect ratio as your screen. Xibo doesn’t rely on designing layouts for a fixed number of pixels, only a fixed ratio.
Then if your screen actually has the same resolution aspect ratio as your layout it should all be fine.
If you have for example images on your layout then you will want them in the same aspect ratio as well so they fit the whole screen/region.
