Need help displaying XML in a ticker
This is my source feed.
https://i5.gomjfreeway.com/Haze/mml-connect
I’ve read through the site a bunch of times before coming here. It looks like there’s no namespace in the XML, but I should be able to still do substitutions by using
[tag|namespace]
If I’m missing a namespace I can just do
[tag|]
I’ve tried every combination of this, forwards and back and still can’t seem to get the XML elements I want into my ticker. I’d be happy if I can just get and on there. Thank you for taking the time to read this stranger.
Which tag are you trying to display please?
Also according to rss validator, this feed is not quite valid, please have a look https://validator.w3.org/feed/check.cgi?url=https%3A%2F%2Fi5.gomjfreeway.com%2FHaze%2Fmml-connect
If it’s your feed, it would be good to fix the problems raised by the validator.
I ran it through the validator as well and saw the errors, unfortunately I don’t have control over it. I could submit a ticket to the software provider and pray :confused:
I’m just interested in 2 things for now.
Element - Rolling Papers - King Size
and
<nonmember_pricing> 3.00000
</nonmember_pricing>
woops, shouldn’t include the tags
I just want title and price.
I’m really not sure if it’s possible to make it work with your current feed.
I tried few things in both 1.7/1.8 with no success, I’d recommend you to contact whoever is responsible for this feed and ask them to fix it.
In the meantime, perhaps you could take the names and prices and put them into dataset in Xibo?
I just don’t want to have to update it everyday :slight_smile: I have a support ticket in with the vendor now and pointed them towards this thread. Hopefully they can get it resolved.
