Não consigo visualizar os meus layout’s mais, tanto na criação, quanto na pre visualização apor terminar
Can you provide more information about this issue, for example:
- What version of CMS are you using?
- Is this a custom or Docker install? What OS is your CMS installed on?
- Is this happening with all of your Layouts?
- When you select the Layouts option in your CMS, is it completely empty or are you able to select the Layout but nothing appears afterwards?
If you can provide screenshots showing the issue, this will also help to understand the issue.
