I have 2 clinics in different towns (one tv in each reception area) and I would like to know if I can manage the content of the 2 display from one location (where my xibo cms is installed). Or do I have to export the content each time I make a change. The content might be a bit different on each display.
That’s exactly what our Cloud solution offers. You would create your layouts in our Cloud CMS and connect both Players to it. Then you only need to manage content once.
I will install all my display and contact you when I will be ready. I think it would be a good solution for me. I am just afraid that 500 meg/ month will not be enough it I use small video clip instead of only JPEG.
Or I will bring the device to my first clinic, sync it and bring it back to my second clinic.
