Multiple CMS's running on the same Server
Can multiple CMS’s run on the same server?
Can they use seperate XMR?
Is this a supported configuration?
Are there any guides to do this?
Regards,
Shahid
Yes, you can - you’d have multiple xibo-docker instances running on the same host system, by specifying them to run on different ports (instructions for this in the manual.
You can run the same XMR or an XMR instance per CMS, at your preference (again, by specifying different ports).
Thank you. I thought that was the case but just wanted to check.
If using direct-lvm mode then do I run each Xibo docker container on a new volume or do I have one volume and let Docker manage it?
Regards,
