Mp4 video without Ton
Hi, i have downloaded a mp4 video from youtube an i had put it in Xibo…the video will ülayong but without a ton. Can you say me what is wrong?
Hae a nice day
Markus
Hi Markus,
Could you please tell us what CMS and client versions do you use?
Could you tell us what kind of error do you see please?
Hi peter,
On both pc’s i have installed the Vers. 1.75
That was i can say is that the mp4 when i download it to my pc the ton i can here… But when i put it in xibo as a video i can’t hear anything. You know what i mean?
Must i install on xibo a audio codec pack?
Best regards
Markus
Hi Markus,
Perhaps you video has 'Mute?" checkbox ticked?
If so, please untick it and save, then it should play the audio
You are the BEST :smile:
This was my problem!! thanks for your help
Markus
