Move installation to different containers
I have installed and upgraded succesfully xibo 1.8.8 on a docker container on Windows 10 pc, now i realized my Synology Nas supports Docker Containers, is there a way i can easily move my installation or my configuration? thank you
I tried with “docker save” to an image that i tried to start on Synology but wont start, it ask me for a command then it says “undefined container does not exists”
thanks
You just copy your “shared” folder over to the new system, then setup your containers to point their volumes to the appropriate parts of the shared folder.
No need to move your existing containers. The containers themselves don’t hold any of your data.
