When attempting to follow the directions to get the Docker Xibo container(?) installed I am getting the following error and have no idea why. Any help would be appreciated.
ERROR: for cms-db stat /volume1/{PATH}/xibo-docker/shared/db: no such file or directory
I think the problem is not with getting the Xibo docker container working, but with the software on the server I am working with. Looks to be some sort of bug causing the issue. Thank you for your time.
