Permissions to those pages, ie layouts, schedule, presumably campaign and library
with that also to regions, playlist, preview.
Additionally you’d need to give them permissions to any existing user objects that they should have access to ie layouts, displays, otherwise they will not see displays on the schedule page for example.
If you set the permissions on a userGroup, then yes each member of that group will have the same permissions.
