Is there a way to change the unit symbol B, KiB, Mib and GiB to B, Kb, Mb, Gb?
The unit symbols cannot be adjusted on your CMS. The units that are currently used are the most accurate way of describing the amount of data. For example, KB instead of KiB could be interpreted as 2 possible values (1000 or 1024 Bytes), whereas KiB is a definitive reference to 1024 Bytes.
