Media Duplicates
I have an image that I have used in three layouts and when I go to Media it shows up three times. Should it not just show up once?
When you copy Layout’s, it give you the option to duplicate the media.
It sounds like you might have done this?
As Justin says, if you copy the layout and duplicate media then it will appear three times.
Similarly, if you design layouts and upload the same media each time, it will create three versions. If you want to use the version already in the library, you should pick “Library” from the list of media to add to your region and find your existing item.
I was creating new layouts from a template I saved of the first one so I guess that does the same as copying one. Thanks for the clarification.
