Media and Layout Library is missing existing Layouts/Media
Hi All,
Have experienced the following after restarting Apache on our Linux server (Ubuntu Server)
Our layouts and media library are cleared, and not showing any of our existing layouts or media. Have checked the media file path, and the media is definitely there. Also the add media button no longer works.
Current on 1.8.8 Xibo CMS, not running in docker.
Appreciate your help.
Regards
Braedan
Nothing in restarting Apache itself should cause that, unless the webserver configuration was changed and restarting it applied those changes.
You have “Audio” as the media type selected. You might try clearing that to see items that aren’t audio in the library incase you don’t have any audio media types.
