Maximum number of devices that can simultaneously connect
What is the maximum number of devices that can simultaneously connect to the latest version of Xibo?
Besides any limits that your hosting can set for you or how much do you believe in your internet capabilities there is no other limit.
Thanks Peter,
  Then on a LAN with updated communications equipment, could be implemented perfectly well 100 customers simultaneously.
Best regards.
That is correct - if you are running a large number of displays you will also want to take care over settings such as your collection interval, auditing/error logging and whether or not you collect proof of play statistics - all of these things increase the load on the server due to increased traffic.
