Maintenance not cleaning database logs
I’m running Xibo 1.7.4 (installed following the xibo guide) on Windows Server 2008 R2 and I’m currently unable to clean my database tables using the maintenance php script.
I have maintenance mode enabled with emails turned off (don’t need this) with logs older than 15 days being deleted. I’m hoping to clean out ~3 months worth of logs filling up my drive as soon as possible since I’m constantly getting low disk usage reports.
When I try and run the command in command prompt (with or without admin priveleges) “C:\my\path\to\php-win.exe” -f “C:path\to\xibo\maintenance.php” secret I don’t notice anything change.
Is there something that I’m missing? I’m wondering if php mail has to be configured regardless if I use the feature or not.
Thanks for any assistance!
It might be failing due to the volume of logs - can you truncate them from the Web UI on the Log page as an initial step and then see if maintenance runs well?
