Maintenance emails
Hi All,
I first want to say how happy I am that I found XIBO. I am now testing for our organisation and seems to work really well. Big thumbs up for you guys.
Now I have setup maintenance email alerts which works. But when at night the screens will be shutdown the IT department receives emails that the screens are down (off course they are we shut them down).
Is there an option to only check the screens between 7:00 and 22:00.
If not I will just disable the emails completely
Kind regards,
Janus van Limpt
Hi Janus
You could schedule the maintenance script to only run between say 07:05 and 22:00. As long as it’s running reasonably regularly not running it overnight won’t do any harm
Alex
Hi Alex,
Thanks for your quick reply, sounds like a good solution,
Thank you :smile:
Janus
