Lost signal on screen
Hi!
Running a set of different screens at our offices is working great on all except one screen. The signal is lost when layouts loop, the screen is looking for resolution and then back to play layouts. Just a matter of ms but screen interface is displaying. How could that be? can I make Xibo to run without interupt the signal to the screen?
How is the device connected to the monitor?
Is it any different than other devices/monitors that does not have this issue?
It is connected with HDMI as the other devices. Android boxes is Minix all of them.
Bad cabling, player or TV (check in that order).
Replace the cable (usual culprit)
Replace the player or switch them around, does the issue follow the player or stay with the TV
Replace the TV
