I have a problem with xibo 1.8 and 17.12.0 docker.
After restarting the pc it seems that everything that was contained in the CMS (media, layouts etc) disappears. Which obliges me to recreate each time the presentation …
While we’d expect that containers restart (stop/start commands) should fix it on docker for windows, there were 2 or 3 cases recently when that did not help straight away.
I’d suggest the same thing I did in these other cases, reset docker to factory defaults, share the C drive again and run the up command.
For a production system, I’d strongly recommend a Linux server. It’s faster and more efficient than Windows, and you won’t have any issues with Docker.
That said, you shouldn’t loose data on Windows with Docker either. Are your files there in the shared directory? ie is all your media stored there as you would expect?
That would be the Player library in c:\Users\username\My Documents. The CMS library (which is where the source data is stored) should be in c:\xibo\xibo-docker-1.8.7\shared\cms\library assuming the directory you’ve given is correct.
seems that evrything is ok in shared folder and in CMS
It is a good news (but pretty strange btw) because I did the exact same things I did in the past days (when I loose everything although I used the command to restart the container…).
I will try now to restart again the computer to check if it works perfectly or if it was some “chance”
Alex thanks for your help I will keep you in touch after the second restart !
