Lost my Index for default display
Hello all,
          Suddenly within Layouts and Default Display i am no longer able to read the Layout Library. Thus i can not select new Media.
All Suggestions welcomed.
I will need more information to be able to help with this issue.
Can you confirm the version of the CMS and Players you are using and whether you have recently upgraded. If any other changes have been made to your CMS or player can you also please let me know.
Can you also clarify what it is you are attempting to do and provide some screenshots of the issue you are having, this will help to understand where the problem lies.
If you do not have any audit logs, I strongly recommend selecting the Report Fault option in your CMS and enabling Debugging/Auditing. After you have done this, try selecting new media again so that the issue is logged. Please confirm any error logs you receive.
Thank you for your reply the problem turned out to be that I ran out of disk space on the XIBO web server!
Time to migrate to 1.8 on a new machine with more disk space as the previous Chap installed XIBO in a 37 GB C: drive with Windows 7 And XMAPP.
Cheer’s
I’m glad to hear your issue is resolved. Should you have any issues with the migration, please let us know.
Many Thanks,
