I know there is a known issue with rebooting windows. I have the latest.sql.gz file in the backup folder. When i start and stop docker it doesn’t import the old backup. What am I missing?
It shouldn’t try and import an sql file when you start and stop.
Your data should all be there in the shared/db
folder already for it to use.
If stopping and starting the containers isn’t recovering things, then please reset Docker and re-share the C: drive, and then up the containers again. Be very sure the path you use in the command prompt is case sensitively the same as the folder you see in Windows Explorer.
