We recently upgraded Xibo CMS to 2.3.0. Since then, it’s been taking around 5 minutes to log in through the web interface. We have a live and a test server (Ubuntu w/ Docker) and it’s happening on both.
This is on different PCs and in different browsers.
What happens after you click login? it just sits there for 5 minutes and then it works?
I don’t think we’ve really changed anything related to how the login process happens - after you’re logged in does moving between pages in the CMS also take a long time?
Is it possible to put the CMS in test mode and see if any logs are generated during that time?
which version did you switch from to this 2.3.0? I can replicate the problem…I have installed 2.3.0 on ubuntu in docker environment. its a fresh install and not an update…i can redo it by installing your old version then try to update to from that to 2.3.0 and see if i will have the log in issue. my production xibo is 1.8.13. I upgraded from 1.8.11 straight to 13 without any issue and i didnt do all what was mentioned in the upgrading instructions…neither did I loose my old custom settings too.
maybe, check the way you carried out the upgrade, files werent transfered properly
I started a fresh environment on my home Ubuntu machine going from 2.2.2 to 2.3.0 using the above method and was able to replicate the slow login issue.
We’ve tested that several times before release and haven’t encountered this slow login issue - I also think that the behaviour you describe is unlikely to be an upgrade issue, just because navigating between other pages seems to be fine.
I wonder if it might be related to two factor authentication - do you have that enabled on the user you’re trying to login with?
Do you have any reverse proxying happening with your Docker install? Or is it just straight in?
Can you spin up a new 2.3.0 and see if you still get the problem?
