Linkedin script
I would like to put my linkedin profile on the XIBO. I use the code created on the developer site from Linkedin:
https://developer.linkedin.com/plugins/member-profile
I past this code in a layout on my XIBO (Running on a Raspberry). If I watch a preview of the design on my laptop I see the profile. But i do not see it on the monitor connected to the raspberry. Other embedded html’s do work… I tried to remove everything on the layout and only put the linkedin profile on it but whitout succes…
Anyone an idea how to fix this?
There’s no officially supported client that runs on the RPi, so I can only assume it’s an old version of the Python client. It’s very unlikely to work as the Python client uses a very old version of Chrome which is unlikely to be able to show modern javascript based content.
@ricardogil may be able to offer you some pointers.
