I am not finding the correct way to license an android player through the CMS server.
When editing the license field I do not know what information to enter.
Hi Rafael, thanks for your message.
The License field is where you would enter your License Pool email address. When you purchase a Xibo for Android License, you will be asked to set an email address for use as the Pool address. Once you have done that, you enter the email address into that field so that the Player will receive it on the next occasion it connects to your CMS. The Player will then License with the Pool.
