Licence check from CMS
Hi
I have version 1.7.9 of the xibo CMS and I’m probably just not looking in the right place, but where can I check my licence usage and available licences plus add more?
cheers
Ben
Is this for a CMS hosted with us? Or for one you’ve installed on your own system?
internal, not hosted
There’s no limitations on the CMS itself in that case. You can connect whatever your server will support.
If you mean Xibo for Android licences, then you can see your licence pool by signing in here:
https://app.xibo.org.uk/login
ah so even though I deploy to android using the internal CMS the licence structure is held in the cloud
I’m new to this and have inherited the system
thanks
Ben
Yes indeed :slight_smile:
