Library size showing incorrect usage
Hi there,
I’ve tried to find something using the search function to no avail. Our xibo installation (Version 4.0.13) is showing 39.xx GB of library usage on the dashboard, as a matter of fact there’s no more than 1.5-2 GB in use.
It’s been updated and upgraded a lot so maybe that’s an old issue still showing but I’m wondering if there is any way to actually recalculate the size in use?
Any guidance would be highly appreciated
Florian
What is the size of your Xibo and data folder as reported by the terminal?
The library folder is 7.0GB so bigger than expected ups. The whole xibo folder is 7.9GB, running on Ubuntu 22.04.4 LTS.
edit: and Xibo up to date running on 4.0.13
Cheers
