Layouts with datasets needs to be republished
CMS Version 4
Player Type android
Player Version 400
Layouts with datasets needs to be unpublished and published again. Otherwise the datasets stay empty on the layout after upgrading from Xibo 3 to 4
Can I just confirm whether you had to make any adjustments to the layout? Or did a simple draft/publish solve the issue?
Were you using a DataSet View or Data Set Ticker widget?
simply draft/publish do the trick ( i selected the element, maybe this is also a requirement)
Dataset view
Thanks, we will run some tests on that upgrade path.
