is there any way to stop the Layout-Refresh every 2-3 min. ?
I use an Minix-Neo U9-H for the Xibo-Player and Xibo Version 1.8.9
regards
Chris
regards
Chris
The layout refreshes when the longest running region has completed so for example if you’ve set up two regions : one with an image showing for 2 min and one for a DataSet to show for 6 min, the full layout will refresh after 6 min.
If you want the refresh to happen later please create a new region, make it really small or off screen using the region editor. Then come back to the layout editor and add for ex text that you’ll leave empty and in the text editor set it up for a longer duration. This longer duration will become the by default duration before refresh.
