Layout Preview does not show the alternative raw
Hi Support
I have a Xibo layout that is displaying a web page. In the web page there is table but only the alternate raws display in the preview as in the attached image.
It looks to me like all rows are displayed (as the Priority is showed), but you’re using black font colour and black background, perhaps you could try to adjust that and see if it will look better?
No I have not used black font or background look at the image I attach here which os from the layout view.
The webpage doesn’t set an explicit background colour, so Xibo renders that as “transparent” or the background colour of your layout.
In the designer, it shows as grey because the region itself has a white tint to it, and white and black make grey.
If you change your layout background colour to white (or any other colour than black), you’ll get what you want.
Thank you. Changing the layout background color worked.
Regards
Lesly
