Layout not updating, logs included
Hello, I scheduled a Layout that consists of a single Playlist (fit to the resolution/width of the Layout). I have run into many issues: sometimes the playlist will only play the first media item, sometimes after that first item, the whole player will restart. But the biggest issue by far is that a playlist will sometimes not play at all. I checked the logs and found the following:
354	08802cd	2024-06-09 00:46	PLAYER	POST	ERROR	WINDEV2404EVAL	Main	Stack Trace: at System.Windows.Duration.get_TimeSpan() at XiboClient.Rendering.Video.MediaElement_MediaOpened(Object sender, RoutedEventArgs e) in C:\Users\User\Documents\Source\xibo-dotnetclient\Rendering\Video.cs:line 142 at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) at System.Windows.Controls.AVElementHelper.OnMediaOpened(Object sender, EventArgs args) at System.Windows.Media.UniqueEventHelper.InvokeEvents(Object sender, EventArgs args) at System.Windows.Media.MediaPlayerState.OnMediaOpened(Object sender, EventArgs args) at System.Windows.Media.UniqueEventHelper.InvokeEvents(Object sender, EventArgs args) at System.Windows.Media.MediaEventsHelper.OnMediaPrerolled(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at XiboClient.App.Main() in C:\Users\User\Documents\Source\xibo- dotnetclient\obj\x86\Release\App.g.cs:line 50
353	08802cd	2024-06-09 00:46	PLAYER	POST	ERROR	WINDEV2404EVAL	Main	Unhandled Exception: UnhandledException: Unable to return a TimeSpan property value for a Duration value of 'Automatic'. Check the HasTimeSpan property before requesting the TimeSpan property value from a Duration.
352	c26058a	2024-06-09 00:45	PLAYER	POST	ERROR	WINDEV2404EVAL	Main	Stack Trace: at System.Windows.Duration.get_TimeSpan() at XiboClient.Rendering.Video.MediaElement_MediaOpened(Object sender, RoutedEventArgs e) in C:\Users\User\Documents\Source\xibo-dotnetclient\Rendering\Video.cs:line 142 at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) at System.Windows.Controls.AVElementHelper.OnMediaOpened(Object sender, EventArgs args) at System.Windows.Media.UniqueEventHelper.InvokeEvents(Object sender, EventArgs args) at System.Windows.Media.MediaPlayerState.OnMediaOpened(Object sender, EventArgs args) at System.Windows.Media.UniqueEventHelper.InvokeEvents(Object sender, EventArgs args) at System.Windows.Media.MediaEventsHelper.OnMediaPrerolled(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Window.ShowHelper(Object booleanBox) at System.Windows.Window.Show() at System.Windows.Window.ShowDialog() at XiboClient.App.RunClient(Boolean screenSaver) in C:\Users\User\Documents\Source\xibo-dotnetclient\App.xaml.cs:line 116 at XiboClient.App.OnStartup(StartupEventArgs e) in C:\Users\User\Documents\Source\xibo-dotnetclient\App.xaml.cs:line 79
351	c26058a	2024-06-09 00:45	PLAYER	POST	ERROR	WINDEV2404EVAL	Main	Unhandled Exception: Startup: Unable to return a TimeSpan property value for a Duration value of 'Automatic'. Check the HasTimeSpan property before requesting the TimeSpan property value from a Duration.
Is there something I’m missing?
Hello @flypie
Welcome to the Xibo community forum.
Missing informations, like player version, server version server type (docker, OS, …), layout content, …
