Layout inside a campaign
Some of our clients have troubles when a layout is inside a campaign. When you make a modification, then the layout is not updated in the player.
And Some stats don’t show when the layout is inside a campaign too, maybe it’s related.
Is this problem already logged ?
Thx :slight_smile:
Your first part is a known issue and will be addressed as part of the 1.8.3 release:
I’m not aware of any issue with stats. From the Players side, a layout in a campaign and a layout not in a campaign are functionally identical, so I can’t see how stats would be missed from one and not the other.
Do you have a worked example that shows this behaviour in a reproducible way please?
I will try to found a way to reproduce that issue, maybe I just made something wrong.
I will open a new thread if I can find a way, thx for your quick answer
