CMS Version and Installation Method
I have installed the CMS version 3.0.3 on a bare metal kubernetes cluster using the following deployment definition:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
replicas: 3
selector:
matchLabels:
app: xibo-cms
template:
metadata:
labels:
app: xibo-cms
annotations:
backup.velero.io/backup-volumes: theme,library,custom
spec:
containers:
- name: xibo-cms
image: xibosignage/xibo-cms:release-3.0.3
envFrom:
- secretRef:
env:
- name: MYSQL_USER
valueFrom:
secretKeyRef:
key: USER
- name: MYSQL_PASSWORD
valueFrom:
secretKeyRef:
key: PASSWORD
- name: XMR_HOST
value: xibo-xmr-intern
- name: CMS_USE_MEMCACHED
value: "true"
- name: MEMCACHED_HOST
value: memcached
volumeMounts:
- name: custom
mountPath: /var/www/cms/custom
- name: theme
mountPath: /var/www/cms/web/theme/custom
- name: library
mountPath: /var/www/cms/library
volumes:
- name: theme
persistentVolumeClaim:
claimName: xibo-cms-theme
- name: library
claimName: xibo-cms-library
- name: custom
claimName: xibo-cms-custom
The CMS seems to be functional. I can register displays and the scheduled layouts get displayed correctly but I couldn’t import a layout I received into my CMS installation. After the progress bar is complete the dialog doesn’t change anymore, and the layout isn’t shown in the layout list no matter how long I wait.
Here the layout in question.
I found an error in the logs, but I can’t make sense of it. It seems to call a function on a null reference:
201,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Loading 1. All Objects = 0",,DEBUG
202,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Install Fonts called with options: {"invalidateCache":false}",,DEBUG
203,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"CMS font CSS returned from Cache.",,DEBUG
204,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Import Layout",,DEBUG
205,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Upload complete for f6aec9a3d329.zip.",,DEBUG
206,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Create Layout from ZIP File: /var/www/cms/library/temp/f6aec9a3d329.zip, imported name will be .",,DEBUG
207,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Loading Layout by XLF",,DEBUG
208,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"Call to a member function getAttribute() on null",,ERROR
209,3ef34b0,"2021-10-13 10:27:34",WEB,/layout/import,POST,"#0 /var/www/cms/lib/Factory/LayoutFactory.php(1136): Xibo\Factory\LayoutFactory->loadByXlf(false)
#1 /var/www/cms/lib/Helper/LayoutUploadHandler.php(82): Xibo\Factory\LayoutFactory->createFromZip('/var/www/cms/li...', '', 1, 0, 0, 0, 'o', 0, Object(Xibo\Controller\Library), '', Object(Slim\Routing\RouteParser))
#2 /var/www/cms/lib/Helper/BlueImpUploadHandler.php(650): Xibo\Helper\LayoutUploadHandler->handle_form_data(Object(stdClass), 0)
#3 /var/www/cms/lib/Helper/BlueImpUploadHandler.php(840): Xibo\Helper\BlueImpUploadHandler->handle_file_upload('/tmp/phpPKhLgp', 'f6aec9a3d329.zi...', 1935, 'application/zip', 0, 0, NULL)
#4 /var/www/cms/lib/Helper/BlueImpUploadHandler.php(142): Xibo\Helper\BlueImpUploadHandler->post()
#5 /var/www/cms/lib/Helper/BlueImpUploadHandler.php(125): Xibo\Helper\BlueImpUploadHandler->initialize()
#6 /var/www/cms/lib/Controller/Layout.php(2390): Xibo\Helper\BlueImpUploadHandler->__construct(Array)
#7 [internal function]: Xibo\Controller\Layout->import(Object(Slim\Http\ServerRequest), Object(Slim\Http\Response))
#8 /var/www/cms/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array(Array, Array)
#9 /var/www/cms/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call(Array, Array)
#10 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke(Array, Object(Slim\Http\ServerRequest), Object(Slim\Http\Response), Array)
#11 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle(Object(Slim\Http\ServerRequest))
#12 /var/www/cms/lib/Middleware/FeatureAuth.php(75): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#13 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\FeatureAuth->process(Object(Slim\Http\ServerRequest), Object(Slim\MiddlewareDispatcher))
#14 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#15 /var/www/cms/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#16 /var/www/cms/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run(Object(Slim\Http\ServerRequest))
#17 /var/www/cms/vendor/akrabat/ip-address-middleware/src/IpAddress.php(91): Slim\Routing\RouteRunner->handle(Object(Slim\Http\ServerRequest))
#18 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): RKA\Middleware\IpAddress->process(Object(Slim\Http\ServerRequest), Object(Slim\Routing\RouteRunner))
#19 /var/www/cms/lib/Middleware/Actions.php(176): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#20 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Actions->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#21 /var/www/cms/lib/Middleware/Theme.php(70): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#22 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Theme->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#23 /var/www/cms/lib/Middleware/CsrfGuard.php(121): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#24 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\CsrfGuard->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#25 /var/www/cms/lib/Middleware/AuthenticationBase.php(78): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#26 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\AuthenticationBase->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#27 /var/www/cms/lib/Middleware/State.php(87): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#28 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\State->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#29 /var/www/cms/lib/Middleware/Log.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#30 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Log->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#31 /var/www/cms/vendor/slim/twig-view/src/TwigMiddleware.php(125): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#32 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#33 /var/www/cms/lib/Middleware/Storage.php(61): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#34 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Storage->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#35 /var/www/cms/lib/Middleware/Xmr.php(67): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#36 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Xibo\Middleware\Xmr->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#37 /var/www/cms/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#38 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#39 /var/www/cms/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#40 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process(Object(Slim\Http\ServerRequest), Object(class@anonymous))
#41 /var/www/cms/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle(Object(Slim\Http\ServerRequest))
#42 /var/www/cms/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle(Object(Slim\Http\ServerRequest))
#43 /var/www/cms/vendor/slim/slim/Slim/App.php(199): Slim\App->handle(Object(Slim\Http\ServerRequest))
#44 /var/www/cms/web/index.php(128): Slim\App->run()
#45 {main}",,DEBUG
I looked inside the mounted volume and under the given path the given ZIP archive exists:
/var/www/cms/library/temp # ls
b87b7863ca f6aec9a3d329.zip fontcss_42e7b35ea6 fontcss_81166587f2 fontcss_a015bed066 fontcss_f6b6cdad8c log_9d2a522f58
I tried to scale the deployment down to one replica, in case that caused the error, but the problem persisted.
Kind regards and thank you for your time.
