Layout does not save all region positions
Hello all,
I am using Xibo - Digitial Signage Version 1.5.0. I have noticed that when I add a region to a layout and save position or change the position of region/s, the region position does not always get saved. The example below is an example of what I am talking about:
  1. Add region 1, add media (picture) to region, resize region and then save its position:
2.Add region 2, add media to region and resize region and click Save Position.
3. Move regions 1 and 2 to new positions and click Save Position
4. Refresh the page and this is what I see:
The regions have reverted back to their old positions. I am working with at least 8 regions in each layout and I noticed that this behavior happens randomly. Sometimes region positions will be saved at other times they will not.
Any suggestions on how to fix this?
1.5.0 is a development preview release from about 3 years ago. It is unsupported.
The latest stable version is 1.7.4. You should upgrade to that and see if the issue remains. I’m not aware of any known issue that would cause that.
Please also note if you’re using 1.5.0 with Linux Players then please be sure you have a suitable upgrade path since the Linux Player is currently discontinued.
