Layout Design - Hover issue for small regions
I have been busy learning the system, and to keep my sanity (questionable already) I have a tiny region that contains the Layout name and version info. This is so I know exactly what layout is being displayed as several are very very similar.
The issue is when you hover over a region its size and xy coordinates pop up inside the region. This covers up the entire region when it is very small, and I cannot drag it to the right place that way. It also obscures the region so it is hard to do a proper placement.
Is there anyway (currently) to suppress this info from popping up. The same data is available via Options for the Region. Don’t see a real need for the duplication either. I’d rather just see it when I want it (via the Options). Can it be made to just show the triangle?
Thoughts?
There’s no way to turn it off at present, but you can zoom the designer in which will make the region displayed larger so you can move it about
