Layout desiging
Is there any regions limit in layout desinging?
What do you mean? Is there a limit to the number of regions you can put on a layout?
No, there is no such limit, but if you do put several regions with content in them, then it may affect the playback depending on the device - I’d suggest testing it before deploying it ‘live’.
hi peter
"What do you mean? Is there a limit to the number of regions you can put on a layout?"
YES
