OS: Windows 10 64 B EDU.
Running XIBO Version 1.7.9.
I have setup a simple layout to display couple of Photos for 7 Sec each.
On client side I have Windows 10 64B Ed.
The Windows Client has been successfully “License Display” in XIBO server.
The Default Layout is set to “Main_Lobby” the one I want to display.
The Display has been Scheduled to run everyday.
The problem is the Client display is showing the default Xibo Display no matter how many times I issue Wake on LAN"
I tried different PCs and all getting the same Default display.
I must be dong something wrong in here.
Could someone let me know what is the issue?
here is the Display Recent Log:
Layout Change to C:\Users\pbs\Documents\Xibo Library\6.xlf failed. Exception raised was: Only 1 layout scheduled and it has nothing to show
